not a farmall but please help
Pat-CT
01-13-2007 19:54:24
ok seince you guys help me so much with my farmall i was wondering if you could help me with a kubota deiseil it sokes when you start it and sounds really bad just had the fluids cahnged but i did not change them could he have put the wrong weight oil in the motor please help ?????
riverbend
01-14-2007 07:03:27
 Re: not a farmall but please help in reply to Pat-CT, 01-13-2007 19:54:24
Our nieghbor has a Kubota diesel. It always blows some smoke on start up and it is so noisy, earplugs are a must.
Look in the owners manual. I think they told how to check and set the fuel pump pressure.
Greg
Pat-CT
01-13-2007 20:32:53
not sure the model its a little compact tractor but it has never had ither used on it and this defintly is out of the normall smokking
Wheat47
01-13-2007 20:24:15
What model??
anyone ever use ether on it?
Jon
dave2
01-15-2007 00:35:26
 Re: not a farmall but please help in reply to Wheat47, 01-13-2007 20:24:15
Why the ether question? I use a quick squirt on mine on the first start, because the glow plugs and wiring were fried before I got the tractor (European IH with a 3 cyl diesel). I've got the stuff together to repair the glow system, but am I going to have further problems???
Sorry to jump into someone elses post.
As far as the smoke on the Kubota, assuming that the fuel system is OK, it could be a lower than recommended fuel quality. Also, if a cylinder is not warming up (glowplug), you'll get some extra smoke. There are some real busy bodies around here, and one of the farmers had an older tractor that smoked like a freight train. Someone reported him, and it turned out that he was using heating oil for fuel. He paid a bunch of money, flushed out his system and put real gasstation diesel in it, and cleared things up. Are you using diesel meant for cars and not truck/equipment grade (maybe a difference)?
Good Luck
Dave
Pat-CT
01-13-2007 19:55:04
sorry i mean it smokes
Dave_Id
01-13-2007 20:25:38
 Re: not a farmall but please help in reply to Pat-CT, 01-13-2007 19:55:04
That sounds pretty normal to me. A diesel usually smokes more when it's cold, and noisier. I had a little Kubota once, and they were noisey.
