H Farmall battery cables
thumbanger
01-14-2007 06:25:06
Can anyone tell how long the cables should be postive to starter ground from neg to start switch and from switch to starter. And what gauage. Thanks for any help
Pete_5959
01-14-2007 08:47:49
 Re: H Farmall battery cables in reply to thumbanger, 01-14-2007 06:25:06
TB...The lengths I used for my H are....Battery to starter switch=28", Starter switch to starter=37" and Battery to chassis ground at starter=20". 00 cable will git r done...
El Toro
01-14-2007 07:50:47
I would use 00 battery cables. If you have the old battery cables you can use them to get the length. You can buy them from these websites too.
Hal
Link
http://www.classicand exotic.com/catalog/electrical/misc0028.htm
John T
01-14-2007 08:05:09
 Re: H Farmall battery cables in reply to El Toro, 01-14-2007 07:50:47
Hal, A point where I definitely agreeeee ee. The bigger the cable (like 00 versus say No. 2) the less voltage drop across it and the less heat energy loss, cuz especially on 6 volt systems the starter needs alllll ll the voltage n energy it can get when youre only starting at 6 volts to begin with, which dont leave much margin for error.
Ol John T and all
