Hey Kfox
thumbanger
01-14-2007 06:32:27
Where you get that 3 point on your tractor would like to see so good shots of it. Thanks
Pat-CT
01-14-2007 07:10:55
 Re: Hey Kfox in reply to thumbanger, 01-14-2007 06:32:27
it looks like this one not sure but i thionk it is Link
kfox
01-14-2007 08:22:24
 Re: Hey Kfox in reply to Pat-CT, 01-14-2007 07:10:55
third party image
Yep, its a Saginaw. It really works well on the
belly pump on my H. If it ever quits raining here, I'll get some better photos. I kinda did a overkill on my plumbing. I hooked the lower ends of the cylinders into the drain on the pump: just in case I needed more oil capacity. It wasn't necessary. I have enough oil to raise the lift and suck oil into the other ends of the cylinders without adding oil. I guess it keeps air out of the other ends of the cylinders. ken
