Will a Flail Mower For a Farmall Lo-Boy fit Farma
BUSTEK
01-14-2007 12:19:44
This is a 48" Mott finish flail mower which was recently removed from a Cub Lo-Boy tractor. The bearings seem to be in good shape with no growling or unusual noises. The deck is solid with some minor rust holes evident. All brackets and pulleys are included. This is a heavy and awkard item so it is for local pickup only. Ok, thats the description in the ad I looked at. Does anyone know if this will fir on the 1949 Cub I have? The Cub had a sickle bar mower already attached, but I"m thinking of removing it so I can mow ditches and "downhill" more easily.
I also have a 1950" Farmall A..anybody know if this will for that? The Farmall A has no sickle bar or pulleys, just the PTO shaft.
Thanx
Ken
DennyF
01-14-2007 12:55:16
 Re: Will a Flail Mower For a Farmall Lo-Boy fit F in reply to BUSTEK, 01-14-2007 12:19:44
Some difference in "ground clearance" between a Cub lo-boy and a standard Cub, but it could probably be adapted with a bit of work on the mounting system, pulleys and the belt, etc.
The A will have a different PTO shaft diameter and direction of rotation, than Cubs do...so that ain't likely "doable".
Bigdog
01-14-2007 12:53:44
The Mott Flail mower brackets for a lo-boy are quite different from the brackets for a standard cub.
