Re: IH 424
Bob Farrell
01-14-2007 13:41:12
I also have a IH-424 that i need some parts for - grill assembly, etc. Haven't found very many posted. If you run into some parts you don't need would appreciate it if you keep me in mind and I'll do likewise for you. Thanks ! Bob F.
Doc Larry
01-14-2007 15:53:50
 Re: IH 424 in reply to Bob Farrell, 01-14-2007 13:41:12
Someone"s had some 424 parts on eBay off and on for the last several months.
bob farrell
01-15-2007 06:20:37
 Re: IH 424 in reply to Doc Larry, 01-14-2007 15:53:50
Thanks Doc. I'm pretty new to computer use, in fact you could put me about two points below "dumb". I will do my best to search E-Bay. Thanks ! bob f.
Doc Larry
01-15-2007 16:25:06
 Re: IH 424 in reply to bob farrell, 01-15-2007 06:20:37
Bob,
Go to eBay home (www.ebay.com). In the upper right of the page, click on "Advanced Search". Under "Enter keyword or item" put "424" without the quotation marks. Under "In this category" select "Business and Industrial" Then click "search title and description" underneath. Then hit the gray search rectangle on the right.
After the next page loads, click on "Agriculture and Forestry" on the left column.
The next page that loads will pretty much show you most of what"s available as far as 424 parts. I would then bookmark that page so you don"t have to go through all this again.
Good luck,
Larry
