Order Farmall Cub Parts Online
Red cub tranny and differential rebuild... help!!!
uh oh
01-14-2007 15:40:04
Can anyone supply a good detailed drawing of the assembly of the differential and tranny? i need to go through these and want to make sure everything is right. also, any tips or suggestions? anyone in missouri hireable to do this? thanks in advance
Nat 2
01-15-2007 05:58:41
 Re: Red cub tranny and differential rebuild... hel in reply to uh oh, 01-14-2007 15:40:04
Someone asked this further down, but I'll ask it outright:
Why do you think you need to tear into it?
FYI, some gear whine is normal on a Cub. It has straight cut gears. Heavier gear lube will help, but even if everything is new, there will be some gear whine, especially in 1st and reverse.
Bob
01-14-2007 21:31:00
It's ALL at this link:
Link
You'll have to "cut and paste" it into your browser, as it can't be posted here as a "hot link".
CNKS
01-14-2007 18:02:07
www.caseih.com has the parts manuals online. Detailed diagrams for every part on the tractor. A printed parts manual would be a great help for you also. Your Case-IH dealer or Binder Books has them.
Haas
01-14-2007 16:00:15
Anyone with a goos set of tools can do the tranny on a cub. The cub is small, so you don't need much heavy lifting stuff. I do think though that you need a parts catalog and a service manual. The cub is pretty simple. Also wonder what problem is there that makes you want to tear into it.
