switching tires and wheels 560 to MD
Brad in WI
01-14-2007 18:49:30
Is it possible to mount 15.5X38 tires on a 12X38 rim or can I put the 14 inch wide 560 wheels onto the M stock centers
third party image
If they will not bolt on can I take the cast centers off of the 560 and mount on my MD so I can put the tires and wheels on.
third party image
BOBM25
01-15-2007 11:18:02
 Re: switching tires and wheels 560 to MD in reply to Brad in WI, 01-14-2007 18:49:30
I have 560 hubs and double bevel rims with 15.5s on my SMTAD. I need new rims and tires. I've been looking around for a good used set, everybody tells me they have a good set on double bevel farmall rims. Always turns out that they have a good set on drop center farmall rims. The double bevel is not really a "Farmall" thing. It is pretty standard on all makes around the age of the 460-560 etc. Seen them on JD's and alot of others. Only difference is color.
sflem849
01-15-2007 09:11:46
I think the more important question is why do you need that much traction on an MD? What did you do to it!!!
Brad in Wi
01-15-2007 09:20:43
 Re: switching tires and wheels 560 to MD in reply to sflem849, 01-15-2007 09:11:46
I have 13.6X38 on it now and some guys that I know are looking for a tire with IH rim. I am going to sell them cause they are all weather checked. I have this 560 in the yard with no motor so I will use the tires off it. I rebuilt the motor and will easily spin the 13.6's right off it in loose soil pulling a disc.
randy hall
01-14-2007 19:14:25
put the hubs and rims from the 560 on your md. they are the same axle.
Brad in WI
01-14-2007 23:25:46
 Re: switching tires and wheels 560 to MD in reply to randy hall, 01-14-2007 19:14:25
I was not sure if they are the same size. Thanks.
Nat 2
01-15-2007 05:55:38
 Re: switching tires and wheels 560 to MD in reply to Brad in WI, 01-14-2007 23:25:46
Yes, you will have to change the whole thing: Rim, tire, and hub.
On the 560, the rims are the "double bevel" type. The MD has a "drop center" type rim.
In a nutshell, the double bevel rims will not fit the drop center hubs.
