1066/1466 wt
ih460puller
01-15-2007 07:17:26
how much more does a 1466 weigh than a 1066 equiped the same
MAGNUM
01-15-2007 14:18:51
 Re: 1066/1466 wt in reply to ih460puller, 01-15-2007 07:17:26
my 1466 weighs 16,000 full of fuel, open station.
Nat 2
01-15-2007 11:11:37
Hmm, wonder where the 570lbs comes from... The only mechanical difference between a 1066 and 1466 is the stroke of the engine, isn't it?
Where'd they sneak in 570lbs of ballast, or did they just list the weights as different so farmers would think they were getting more tractor for their money?
randy hall
01-15-2007 16:16:06
 Re: 1066/1466 wt in reply to Nat 2, 01-15-2007 11:11:37
the final drives are wider and the axles are heavier on a 14. i have owned my 14 since it was almost new.
IaGary
01-15-2007 11:55:25
Heavier rear end in a 1466.
The 966 and the 1066 had the same rear end.
The 1086 went to the heavier rear end the same as a 1486.
Gary
IaGary
01-15-2007 10:48:52
The shipping weight with a cab, by the book I have says:
1066 = 11860
1466 = 12430
So a differance of about 570 lbs.
Gary
Retcol
01-15-2007 09:03:42
According to the 1973 Nebraska tests, the 1066 weighed in at 13,345. However, I think the tractor had dual wheels and a cab. The 1466 weighed 13,670 with duals and a cab. These weights were before any additional ballast was added.
Allan In NE
01-15-2007 09:05:57
 Re: 1066/1466 wt in reply to Retcol, 01-15-2007 09:03:42
Oh heck yeah,
Fueled up and ready to go to the field, they'll crowd 15K awfully darned hard.
Allan
