farmall m whats wrong? is it worth it.
james braley
01-15-2007 10:21:33
looking to buy a farmall m from a guy. but it has whrling sond in the engige. what is that? but it has 50%ruber and he only wants 950$ is it worth it.
chad 9999
01-16-2007 18:12:20
 Re: farmall m whats wrong? is it worth it. in reply to james braley, 01-15-2007 10:21:33
if u can think about the sound and it sounds like the rumble of gears then I have had two that the gears in the front are running dry because of the oil hole are clogged up
JT
01-15-2007 13:03:32
Sounds as though you might be descibing a bad bearing somewhere, you just gotta find out hwere it might be. As for worth, IMHO, not more that $500.00 tops, they are only worth 1000.00-1500.00 in good,clean running condition
ebbsspeed
01-15-2007 11:49:25
Hydraulic pump? Power Steering Pump? Bearing in water pump? Panty hose snagged on fan? Hard to tell from the description..... .....
james braley
01-15-2007 11:12:37
cant say. it just what the guy told me.
Nat 2
01-15-2007 12:58:43
 Re: farmall m whats wrong? is it worth it. in reply to james braley, 01-15-2007 11:12:37
Welp, then we can't say, either. Nobody knows what a "whirling noise" is, because that's not a word normally used to describe mechanical noises.
If you can't go and listen to it yourself, then either offer the guy $500, or pass on it. A complete M with major engine problems is worth $500, and then you can either restore it or part it out.
Brian in NY
01-15-2007 10:51:53
A whirling sound? Could you decribe it more specifically?...and what part of the engine is the sound coming from? Does it change in pitch when the clutch is engaged?
KRUSS
01-15-2007 13:33:13
 Re: farmall m whats wrong? is it worth it. in reply to Brian in NY, 01-15-2007 10:51:53
I thought they all made whirling sounds. It's when it stops making sound at all that a problem has developed.
