Farmall H Gear Oil
Gary Puckett
01-15-2007 17:53:49
I am changing the oil in my H transmission. I have noticed at a tractor supply store two gear oils: SAE 85-140 and SAE 80-90. Which one should I use,or what would you recommend?
Thanks
randy hall
01-15-2007 19:42:23
 Re: Farmall H Gear Oil in reply to Gary Puckett, 01-15-2007 17:53:49
i use 140 weight gear oil in the m's that i redo. it won't leak nearly as easy as 90 weight and it is no heavier than the old crusty oil that you will drain out of your h.
chuck46
01-15-2007 19:34:18
Hi, I am a big believer in Hy-tran for all tractors I use. My H and WD9 have had it for more than 30 years, I have magnets and filters on them so I can see how much wear there is, and after several thousand hours I know they are doing better than they did with the heavy oils. I used to see a bearing turn in the housing once in a while, but not now. I put a street ell in the check hole, turned up so the level is 2 inchs higher. Good luck, Chuck
Tom Windsor
01-15-2007 18:48:17
Make sure you flush that thing out good!!
PORKY B.
01-15-2007 18:19:45
Use the 80/90 gear oil
