140 Hydraulic Pump
Waljohn
01-16-2007 12:50:43
Does anyone know if they make a rebuild kit for the 140 pumps, and if so, where I could get them? I have 2 pumps that are leaking into the crankcase.
riverbend
01-16-2007 16:25:12
 Re: 140 Hydraulic Pump in reply to Waljohn, 01-16-2007 12:50:43
If it turns out to be a Cessna pump, and you really do need the whole gasket set, there may be a company in Kent Washington that has them. I have ordered one, but have not got it yet. IH will have the shaft seal.
riverbend
01-24-2007 15:34:15
 Re: 140 Hydraulic Pump in reply to riverbend, 01-16-2007 16:25:12
I did get the parts and they look like a perfect match. The company is Spencer Power Systems in Kent, WA.
Greg
gene bender
01-16-2007 16:03:28
you dont need a repair kit just the seal and if the journal is grooved you need a speedy sleeve for the shaft.
El Toro
01-16-2007 13:32:16
Your local Case/IH dealer should have a repair kit. They will need to know which pump you have whether it's a Pesco or Thompson. Hal
Waljohn
01-16-2007 15:31:25
 Re: 140 Hydraulic Pump in reply to El Toro, 01-16-2007 13:32:16
Thanks, Hal. Will give them a try.
Walt
