attn chads 450 cam
olivereater
01-16-2007 16:59:56
where can i find a 450 cam and an m&w 6inch stroker kit do they have a website or phone number
ChadS
01-17-2007 09:39:37
 Re: attn chads 450 cam in reply to olivereater, 01-16-2007 16:59:56
Ive got new 450 cams ready to go. I can get you the crank, pistons and everything you need to put one together, its not an original M&W crank, its a stroked crank. Usually what we do is, if someone needs a kit built, send us the rods, and the crank and we build the rods, and have the crank built and shipped back to you. We can also do most of the grinding needed to clear 6 inch, and tell you where to grind in the block so the rods clear. Its not hard at all to do. 574-893-7437 ChadS
City-Boy McCoy
01-16-2007 17:36:56
If nobody can answer your question here (and I sure can't), you might go over to the Pulling Forum and ask the same question. mike
