HD SM clutch
markloff
01-16-2007 18:03:38
Hello,
What is a good heavy duty clutch set-up to put in a Super M? I'm looking to handle about 70-80 HP. I'm transplanting a 2-71 Detroit Diesel into it and want to upgrade as the tractor is now split and I'm in the process of gathering and machining parts. I have what I believe is a Rockford clutch on it now (12 springs on the pressure plate). Would that be good enough with a rebuild and a new clutch disk? Can you put new or heavy duty springs in that particular pressure plate or would it just be more cost effective to get an aftermarket one? What the best route to take here?
Thanks,
Mark
r4etired
01-17-2007 06:25:17
 Re: HD SM clutch in reply to markloff, 01-16-2007 18:03:38
Mark, Just buy a new Rockfort clutch pac,you get it all. Thats what I used in my M with a IH345 V8 in it. Most clutch problems are operator errors
the tractor vet
01-16-2007 19:08:07
Myself i would go with either the stock clutch for a 560 or if ya want heavier then a stock 706 clutch but if ya do that ya may want to join a heath spa and do some leg streinghting stuff as on the one S/MTA that we put together the 560 clutch was not enough and went to the 706 clutch . Ya don't want to spend to much time holding it down now and best have a good hold on the steering wheel so ya don't push yourself out of the seat. And Oh BTW BMD stuff is not realy that good if ya want quality then go with Hy Capacity 19 years as a dealer for them and NEVER one problem . But did a ton of work that was brought to me that one other guy did and that is what he was pushen lost od centers pulled out of clutches ans several T/A failures tha they or he would not stand behind . At least with me ya go a 2 year warranty and never had to do a Warranty job
PORKY B.
01-16-2007 18:54:40
Mark I would go with a ceramic clutch, either a 4 or 6 pad disc.B.M.D offers a good clutch and pressure plate kit. We have had good luck with it in pulling tractor.
