12 Volt Coil
DFL
01-17-2007 10:27:17
What would the reason be someone would install a 12 volt coil on 1943 Farmall H which has a 6 volt electrical system.
Janicholson
01-17-2007 10:31:36
 Re: 12 Volt Coil in reply to DFL, 01-17-2007 10:27:17
Two reasons:
If it had been converted to 12 at one time, or if the coil it has is rated for having an external resistor (though it might say 12 volt on it, it is close to a six volt coil, and is usewd with a resistor on 12v, or without on 6v) If it indicates "for use with a external resistor", and does not have one in the circuit, it will work fine on a 6v tractor. JimN
Nat 2
01-17-2007 13:04:03
 Re: 12 Volt Coil in reply to Janicholson, 01-17-2007 10:31:36
Third reason: Someone who thought a coil was a coil put it on by mistake.
Janicholson
01-17-2007 17:33:51
 Re: 12 Volt Coil in reply to Nat 2, 01-17-2007 13:04:03
True it is. JimN
