Farmall a, B or C
Tom Widnsor
01-17-2007 16:28:17
Does anyone have a sleeve out of an A, B or C that they can measure up and give me the specifications?
TW
Janicholson
01-17-2007 17:17:29
 Re: Farmall a, B or C in reply to Tom Widnsor, 01-17-2007 16:28:17
Dear Tom,
There are very different sizes on these tractors. There are 113 inch engines, 123 inch engines, 123 sized blocks with 113 inch displacement, 113 sized blocks that have kits in them to boost displacement, and the same block (or direct offspring) are found in combine engines of mid 150s displacement. Some blocks have intended displacement on the right side toward rear, some do not. Let us know what you are doing and we can be way more precise. There are differing bores, differing sleeve hole sizes and differing sleeve thicknesses. Some bigger engines are made sleeveless (I think) JimN
Tom Windsor
01-17-2007 19:17:14
 Re: Farmall a, B or C in reply to Janicholson, 01-17-2007 17:17:29
Do you have the specifications on the 123 engine?
El Toro
01-18-2007 06:04:59
 Re: Farmall a, B or C in reply to Tom Windsor, 01-17-2007 19:17:14
The Super C C-123 engine used a sleeve that mearured 3.4375" on the overall diameter at the seal. You could install 3.250" sleeve kits in this block without any machining. Hal
PS: I think they had 3.1875" kits too.
Tom Windsor
01-17-2007 19:19:44
 Correction C113 engine in reply to Tom Windsor, 01-17-2007 19:17:14
I mistated it a moment ago. it is a C1134 and not c123
El Toro
01-17-2007 16:49:45
I have the diameter of the sleeve at the seal to be 3.312". Hal
Red Dave
01-17-2007 16:41:03
Yes, I have the set of sleeves I took out of a B.
What do you need? The ones I have are not originals. They are for 3-1/8 diameter pistons.
You can e-mail too if you like.
