Wireing H Farmall
thumbanger
01-18-2007 17:38:07
Can anyone send me a wireing diagrahm for 41 H with mag that you can understand what I have is very confussing wires are to close togeather you cant make heads or tails of it waste of money. Thanks in advance
Jossette
01-19-2007 15:19:36
 Re: Wireing H Farmall in reply to thumbanger, 01-18-2007 17:38:07
third party image
wire
Nat 2
01-19-2007 05:19:58
Sounds like you've got a poor copy of the original wiring harness diagram from the owner's manual. The ones I have are very easy to read and trace, plus as I recall, the wires are numbered on both ends of the diagram.
Hopefully someone will post a link to Bob M's handy-dandy wiring diagrams. They're simplified and color-coded to a point.
Worst case, you can purchase new wiring harnesses that are all labeled up and easy to install from a guy in Alden, NY. A little pricey, but it's original-style wire, and even a caveman could install it with the instructions provided.
Bob M
01-19-2007 06:07:50
 Re: Wiring H Farmall in reply to Nat 2, 01-19-2007 05:19:58
Punch below for a link to a diagram for a mag-equipped H.
If you prefer a pre-made harness I suggest Agri-Services in Alden NY (www.wiringharnesses.com).
I've not used their products myself. But several people who have tell me their harnesses are first class.
