Farmall B head gasket guestion
Dave U
01-19-2007 11:33:58
I am planning to put the head back on my B this weekend. I have a new gasket.. Sould I use copper sealent as my IH dealer suggests?
Roger Mills
01-19-2007 16:49:24
 Re: Farmall B head gasket guestion in reply to Dave U, 01-19-2007 11:33:58
Just a point to look at on the gasket--there are two that fit the engine correctly, one has large water passage cutouts that match the head and block, (the one you want), the other has smaller holes, (the one you DON'T want),---why-because the stock B does not have a water pump and the Thermosiphon cooling will NOT work properly with the wrong head gasket!!
Red Dave
01-19-2007 15:03:42
Yes, and don't forget to re-torque it after it warms up too.
RustyFarmall
01-19-2007 12:30:24
Copper coat is a good product. If the dealer recommended it, you should use it.
Berry450d
01-19-2007 12:10:03
Dave it might sound silly, but plain aluminum spray paint on both sides allowed to dry until tacky works as good as anything. I was tought this by my high school Vo Ag teacher and, I have used this for 25 years never any problem at all.
Janicholson
01-19-2007 13:57:28
 Re: Farmall B head gasket guestion in reply to Berry450d, 01-19-2007 12:10:03
Berry, my only issue with spray paint is the fact that from product to product there is no consistancy. The result may be OK, or it might have organic material in it that decomoses at 275 degrees. That is why I recommend Copper Coat. JimN
Berry450d
01-19-2007 15:37:45
 Re: Farmall B head gasket guestion in reply to Janicholson, 01-19-2007 13:57:28
Jim I am not saying it is better, I am saying this works,and it works good. I have farmed and built houses all my life and the books are not always right. THis is just a suggestion from a old shade tree fixit man.
Janicholson
01-19-2007 11:45:49
Spray Copper Coat goes on all mine (unless directed by specific instructions not to). JimN
