9-speed bearing #'s
Randy as in Ran
01-19-2007 15:54:40
Hi All , Does anyone have the bearing numbers for the bearings that are different from the stock bearings in a M's M&W 9-speed and which ones are the different ones from stock ? Anything you could could add about seals or anything else would be nice also . I'm going to have to have someone else do the job since I can't get into the shop at work due to the cranes we are rebuilding this winter . I really wish I could afford at least a garage :( but it's not my destiny . At least this guy works fast and has many , many years of experience . He say's he can do it in four or five hours if the parts are at hand and the bolts don't break . But that doesn't include a thorough cleaning I'm sure . He did say to be prepared to replace the axle bearings so I looked at the price of those bearings and got lock jaw ! If they are bad they are going to stay bad till next year or later unless I can find a donor tractor for some good used bearings which I know is probably not a very bright idea but at $160 dollars a piece ( not through IH ) I'll take my chances for a year or so . So can anyone help with the bearing numbers ? Thanks ! ...Randy
SKK - Big Red Fan
01-20-2007 08:59:05
 Re: 9-speed bearing #'s in reply to Randy as in Randy-IA, 01-19-2007 15:54:40
I checked the M&W parts listing last night. NO bearings listed.
Think I still owe you the manual. Had a couple of surgeries this past couple of weeks, and it has slowed me down. Will try and get the instructions in the mail this weekend.
01-20-2007 15:23:01
 Re: 9-speed bearing #'s in reply to SKK - Big Red Fan, 01-20-2007 08:59:05
Hi , I guess I missed that you were having troubles . Get well soon ! And thanks again ! ...Randy
D Slater
01-19-2007 16:16:30
Bearings and seals are all IH. If you have lever shift M&W, there's a seal that shift shaft goes through that's not standard IH. You can match it up at a seal and bearing supplier.
01-19-2007 18:49:28
 Re: 9-speed bearing #'s in reply to D Slater, 01-19-2007 16:16:30
Hi , Are they the same part numbers as in the M parts book or just some random IH parts made to work . The reason I ask is that I want to get everything bought before we start and I don't want to have to order bearings after we take it apart so I want to be sure . I talked to the parts guy and he didn't know if they were the same . Sorry to be redundant but I just want to be as prepared as possible . Thanks ! ...Randy
D Slater
01-20-2007 07:59:44
 Re: 9-speed bearing #'s in reply to Randy as in Randy-IA, 01-19-2007 18:49:28
Bearings were not part of M M&W 9 speed kit. Original IH bearings or there likness were reinstalled. On later M there was a change of size of input shaft bearing and a few upgrades by IH on main shaft pilot bearing.
01-20-2007 14:43:56
 Re: 9-speed bearing #'s in reply to D Slater, 01-20-2007 07:59:44
Thanks for the info . The dealer has all the bearings for a stock rebuild on the shelf . I don't have a late model ( '47 ) so I guess it'll work . Take care ! ...Randy
