change over from low comp, to hig compression hedi
BAXTER
01-19-2007 18:49:33
i am putting a high comp. head on my M and before i had a low comp. so i was just wondering do you have to change any parts in the motor...also the rockerarms wont fit on the hihg comp. off the old comp. and i have ansked many people but they said it will fit. but it simpily does not, so any where to get a new rocker arm???
ChadS
01-21-2007 09:08:01
 Re: change over from low comp, to hig compression in reply to BAXTER, 01-19-2007 18:49:33
Are you sure the assmbly is put together right?? the rockers should be aimed towards each other, if they are aimed away from each other, someone has taken it apart and put them on backwards. That would make one line up, and throw the other one off, side to side,,,, If the springs are compressing to get them to line up, for sure they are on backwards on the shaft. Other than that, its a bolt on deal,,,, can you show us a picture?? Chad
Baxter
01-21-2007 10:08:37
 Re: change over from low comp, to hig compression in reply to ChadS, 01-21-2007 09:08:01
I no i am no expert at engines...and i could be wrong..but where the rocker arm assembly bolts down to the head..it does not line up there either...so it has to be wrong right?
i will send any body a picture hat wants it..becuse i can figure out how to put it on the forum..sorry
randy hall
01-20-2007 14:00:13
the rocker srms do interchange the heads for an m thru 450 are all the same height. the valves are all dirrerent lenghts depending on the type of head. i'm guessing that you are kind of new at engine work. the rockers aren't near the valves because they need adjusting or your gas head has valves from a low compression head installed in it and they would be too short, randy
BAXTER
01-20-2007 11:25:56
ok, i just went to the shead and tried to put the rockers on, they match up where they are bolted down to the head, but where they are supposted to make contact on that little peice of meatal on top of the vales, the rockers do not fit on there...there too short, like if i get them to match up on one side they will be off on the other side
BAXTER
01-20-2007 11:09:36
hmmm the casting number on the new head is 8060-DB i dont know whats goin on then..i still need to get the old head casting number
Thanks
-Ryan
colekicker
01-20-2007 11:02:54
Just looked in the parts book. All of the rocker arm assemblies are the same. The levers fit H and M and their simmilar numbered models. So, since the part numbers are the same, then something else must be the issue.
Will Sick
01-19-2007 19:25:44
The valve length is different in different heads. That might be why it appears that the rocker arms don,t fit.
colekicker
01-20-2007 11:12:47
 Re: change over from low comp, to hig compression in reply to Will Sick, 01-19-2007 19:25:44
As long as the correct valves are being used in that head, there should not be a problem. So, looking at an LP head, it will have a small combustion chamber. The top of the combustion chamber will come a lot closer to the piston. For it to reach the rocker assembly, it has to be long. For a kero head, the combustion chamber is quite a bit larger. The top of the chamber is much further away from the piston. With this head, the valve stem will be shorter. Now, the 8060, being the later gas head, the valve length will fall in between the two.
Basically, kero head and low comp gas heads first. To keep as many parts the same, the dimensions of the head castings changed along with the valve length, but keeping the rocker assemblies the same. Same was done when the LP heads were developed with the 264 and 281
BAXTER
01-19-2007 19:08:42
i think the head casting number on the high comp is 8060 but not shure ill have to check tomorrow and ill get the ser. number tomorrow, its a 1950 M..
Janicholson
01-19-2007 19:01:50
The answer is we need more info. There are at least five different options involved from distillate heads to Propane heads and gas heads for various engines in that series in between. Head casting numbers will help, as will the year/serial # of the engine it will go on. Too many unknowns. JimN
