Recommended Rear Tire Pressure
City-Boy McCoy
01-20-2007 16:45:49
Howdy, boys. As some of you may know, I have a couple of Super A's and a Super H. I have always put about 12-15 lbs of air in the rears. Now, somebody has recently told me I ought to have 35-40 lbs in the rears, unless I have fluid in the back tires, in which case, I should have 12-15. I do NOT have fluid in the rears. Fellows, what rear tire pressure do you recommend for the rears? (I would rather get my info from guys in whom I have confidence.) Thanks. mike
Roger Mills
01-21-2007 08:59:00
 Re: Recommended Rear Tire Pressure in reply to City-Boy McCoy, 01-20-2007 16:45:49
Randy has the right approach for hard pavement. Here is what IH reccommended in the operators books: Front; 4ply 28, 6ply 36. Rear; Minimum for 4 and 6ply on 4, 5, 6, and 7" Duals 20 and all other sizes 12. Maximum for 4ply 4, 5, 6, and 7" Duals 24 and all other sizes 16. Maximum for all 6ply sizes 24. Also says to increase pressure on furrow side by 4 lbs. when plowing. By this-4ply single rears range from 12 to 16 lbs and 6ply single rears range from 12 to 24 depending on use. War tires were 28 front and 12 rear for all sizes except furrow side rear at 16 only when plowing.
City-Boy McCoy
01-20-2007 17:07:16
 Thanks, Boys in reply to City-Boy McCoy, 01-20-2007 16:45:49
Thanks, boys. That's JUST what I thought my ownself. You are the best.... mike
Randy as in Randy-IA
01-20-2007 18:35:02
 Re: Thanks, Boys in reply to City-Boy McCoy, 01-20-2007 17:07:16
Hi , I don't know if this will work on a tractor tire or not ( and it also depends on if you have any flat pavement ) . I used to drive four wheel drive trucks for river running with 39" tires on them ( half ton short box chevy with 39-15-15 Mickey T's baja's ) . In order to get a good road ride I got the tire wet ( Or rubbed chalk on the tread ) and drove it down the road , if the whole tread wasn't touching the pavement I let out air till it did then dropped it about 2-3 pounds more . That made sure that the tire wasn't rounded ( crowned ) but it wasn't underinflated either . The tires I used only got 18psi on the street and I aired down to 3-4 psi offroad . The sidewall called for 35-36psi max pressure . Like I said , it worked good for a pickup but I don't know if it'll work on a tire as big as a tractors tire . The truck tires weren't radials either but bias belted . For what it's worth ...Randy
NDS
01-20-2007 17:06:48
Firestone recomends MAXIMUM pressures for thier 4 plys from 14psi to 20psi and 22psi to 30psi for 6 plys depending on tire size.
Charles McNelly III
01-20-2007 17:19:13
 Re: Recommended Rear Tire Pressure in reply to NDS, 01-20-2007 17:06:48
Auto manufactures recommend changing the oil anywhere from 7,500 to 15,000 miles too. I don't think so. Use what your gut tells you, it's usually not far off. :)
Charles
Erik in WI
01-20-2007 16:57:38
NEVER put 35-40 psi in a tractor tire! EVER! Even when trying to seat the bead! Who ever told you this is not right. The psi of the tire is the first numbers in the size. For example, 18.4 what evers get 18.4 psi, fluid or no fluid.
Brian J
01-20-2007 17:42:07
 Re: Recommended Rear Tire Pressure in reply to Erik in WI, 01-20-2007 16:57:38
First time I've heard that one!!! If you can read the tire size, then I assume you can also read the recommended inflation pressure on each tire also.
Janicholson
01-20-2007 17:25:23
That would be ok for that one tire as a coincidence.
It is (no offense) bad policy. Big tires with less load need less pressure small section tires with proportionally greater load need higher pressures. The key id the tire footprint in dirt. and is very different between bias ply, and radials. Goodyear Ag website has quantities of data on contact pach, traction, and ballasting driven ag tires. Please do not put in pressure depending on the tires size, it can be dangerous/wrong. JimN
KRUSS
01-20-2007 17:08:32
So you're saying I should put 32 lbs in my combine tires? I don't think so.
Paul Shuler
01-20-2007 16:52:40
I run about 10 psi in the rear and about 35 in the front tires.
old
01-20-2007 16:52:47
10-15 PSI is for normal running and the 30 or so is to seat the tire beads. Never even try to run them with 30 plus in them or they will sort of sit like a rubber ball and you will bounch all over the place when your driveing it. Most tires will have a place on them telling you the PSI need but not all of them have that. Use more air to have a narrower foot print and less for more traction and wider foot print. Oh by the way it doesn't matter if you have air or fluid in your tires its still the same PSI at all times
