hyd.
james braley
01-20-2007 17:38:09
have an M. there is a stub sticking out of the place where the hyd. contrall lever was. why is it there? is it fixable? if so how? sombody also added a extra hyd. systime to.
Janicholson
01-20-2007 19:39:31
 Re: hyd. in reply to james braley, 01-20-2007 17:38:09
third party image
Ill add a diagram to the fine info you noe have from below.
CNKS
01-20-2007 18:10:43
If I'm reading you right, someone installed a distributer mounted pump (live) and removed the lift all control lever because he no longer needed it. The lever mounted on the stub. If the lift all is being used as reservoir for the live pump, and the other outlets AND the pump are there, you can find a control lever and use both. But, it makes more sense to simply add more spool valves. I assume yours has one somewhere.
City-Boy McCoy
01-20-2007 18:02:50
If somebody added another hydraulic system, then the old one is probably just being used as the reservoir for the added system. (Hard to say without photos.) If that is the case, there is no reason to fix the broken stub, unless you are into purist level restorations. mike
