roosa master - what does this fit?
Beckey
01-20-2007 21:27:34
I have a Roosa Master pump that I think has never been used. I need to figure out what it goes on. Number on it is - DBGVCC631. Bought it with other tractor parts and those parts were for a Model 560. Does it belong to this tractor? Any help appreciated.
Shovelman
01-21-2007 08:42:01
 Re: roosa master - what does this fit? in reply to Beckey, 01-20-2007 21:27:34
According to my Stanadyne applications book, the 4BF was used on the White Motors DD298 engine in a generator application.
The customer part number is 290674.
I hope this is helpful.
Scott
Beckey
01-21-2007 10:05:52
 Re: roosa master - what does this fit? in reply to Shovelman, 01-21-2007 08:42:01
Thanks Scott. I thought this might have been for an International Tractor since the other stuff was, and had come from a shop that repaired International equipment. I will probably put on eBay and see what happens. Appreciate the info you provided.
Beckey
Shovelman
01-21-2007 05:21:01
We need more numbers. There should be suffix numbers/letters after 631. Also, the other numbers on the tag would be helpful.
DBGVCC-631 pumps were primarily used on White engines.
Beckey
01-21-2007 08:27:21
 Re: roosa master - what does this fit? in reply to Shovelman, 01-21-2007 05:21:01
Here are more numbers. DBGVCC631 4BF 1500
I hope this helps.
Sorry for not including.
