engine serial numbers, 263-291-301
jpl
01-21-2007 15:51:56
looked in numbers search but cant find anything on eng numbers, the engine i have is number 387716r1, the head is a 706 by number in ulav-tlib book, hate to tear off head as good running engine. dont know if i have a 263 or 291 or 301. any help, save me buying gasket set etc. maybe a combine eng
jpl
01-22-2007 08:23:49
 Re: engine serial numbers, 263-291-301 in reply to jpl, 01-21-2007 15:51:56
BAD KEYBOARD, CHANGED, OK NOW, PULLED HEAD AND HAS 30 OVER IN IT, NO SLEEVES SO I;M HAPPY ITS A 301, THANKS FOR HELP. BORE IS ALMOST 3 7/8.
jpl
01-22-2007 08:16:10
cld nt fnd nmb n BLCK TK 0FF HAD TS A 301 THANKS ALL
ejr-IA.
01-21-2007 20:24:52
It should be stamped on the left side of the block what cid it is.If it is a 301 its stamped on the right side up top front of the block.
CNKS
01-21-2007 19:06:34
Look up the parts for the 706 or virtually anything else in the online catalogs on www.caseih.com. If there was a serial break (I doubt it) it will be listed. And if there are serial breaks they are "usually" chassis serials, not engine serials.
El Toro
01-21-2007 17:16:17
That appears to be a casting number, someone may be able to identify the engine. Look under No1 sparkplug for a flat spot that may have a SN. Hal
El Toro
01-21-2007 17:16:09
