best value tractor
moutainman
01-22-2007 15:37:07
I am new to tractors i want to pull do some farm work and mabey plow...money does not matter...got that..just whats the all around best value for a farmall..i want newer then 45'..thanks
City-Boy McCoy
01-24-2007 16:04:54
 Re: best value tractor in reply to moutainman, 01-22-2007 15:37:07
Hey, "High-roller Hot-shot"; I've got your Super H for only $230,000. mike
Brian in NY
01-24-2007 07:02:52
You can probably buy an H or M the cheapest, because they are very plentiful.
Value is in the eye of the beholder.
I don't need anything as big and powerful as an M, so it doesn't have much value for me, where a much less capable Farmall B has more sentimental value to me.
Steven@AZ
01-23-2007 06:11:23
I would say the best all-around value for a Farmall would have to be an H or M. Cheap to buy, cheap to repair, reliable and easy to work on.
Dennis in NC
01-23-2007 05:17:01
Money does not matter . heck i'll sell you what ever you wont - got a CUB i will let go for 100k got a 230 for 250k or better offer. i'll sell you keith tractor for 300k + tax and handleing fee.
Keith-OR
01-23-2007 06:53:11
 Re: best value tractor in reply to Dennis in NC, 01-23-2007 05:17:01
Take Dennis's offer for his Cub or 230, I'll throw Dennis in, and will drop discount asking price to $200K...you can pull him around all you want..He works cheap and don't eat much!!!:-)
Keith
Hugh MacKay
01-23-2007 02:16:15
mountainman: You don't say how many acres, however if I wanted to plow up to 25 acres maybe even 40 acres, depends on how much time your prepared to spend plowing. I'd go 100, 130, 140, SC, 200 or 230 with fast hitch 2x12 plow. I've plowed as much as 100 acres per year with one of these. I don't recommend it though, lot of hours. I say this with small tractors, as I'm not sure the industry ever built anything better than fast hitch in the light hp class.
My next step for 25 to 150, maybe 200 acres would be 656, 666, 686, 706, 756 or 766 diesels, with 4x16 semi-mounted plow. These are modern day tractors with excellent draft control, probably no company has improved on that 3 point hitch since. They are very efficient tractors, both from a durability and fuel economy point of view. Looking to the future and some other functions you may wish to use your tractor for, I'd stay newer than 1963 in tractors over 35 hp, you'll buy that draft controlled 3 point hitch for very few dollars. I say this just comparing price against older Farmalls with Fast Hitch and standard drawbars.
Of course if you want to plow more than 150, just up the hp and the plow bottoms, just stay newer than 63. If you want to plow big acreage then you could go 350 hp articulated and 10 bottom plow. That is how I'd match them up, look at your acreage to plow and go from there.
jfee
01-22-2007 16:52:41
i have had h, m,350u,706g,806d,656g,666g,1690case,3020jd and some not worth mentioning. but my favorites were 656 666 for the money.
Janicholson
01-22-2007 15:46:55
SMTA Diesel has it all, including expense.
HAS
01-22-2007 15:44:08
It depends on how much acerage you want to work. Anything from a cub or super A for a garden spot, acre or so to an H or an M for several acres. You can tell I'm partial to the letter series. I'm not too familiar with the later models, but the later replacements to these are good too. I would think you would want a row crop tractor if you are going to plow & cultivate. They're more versatile for that type of work. If you want to really pull heavy, you'll want a Super MTA.
My opinions.
MN Dave
01-22-2007 16:07:30
 Re: best value tractor in reply to HAS, 01-22-2007 15:44:08
go with a 400 gas instead of a SMTA, basically same tractor, newer and 1/3 of the price.
