Hugh MacKay/Tractor Vet
Allan In NE
01-23-2007 02:53:43
Mornin',
I've got to mount two extra forward field lights on a cabbed tractor that already has two additional rear field lights and need to put all behind an additional relay.
Where did you guys mount the relay? I'm thinking over there on the right side in the area of the the cab relays?
Thanks,
Allan
Hugh MacKay
01-23-2007 08:14:59
 Re: Hugh MacKay/Tractor Vet in reply to Allan In NE, 01-23-2007 02:53:43
Allan: I've forgotten exactly how I did this I think I left all factory lights except flashers on the original factory switch. I added a 3-4 fuse-switch panel for added working lights and the flashers. I know when done my lighting was on 4 circuits. I did 560, 656 and 1066 all the same way, and the reason I'm not remembering exactly how it was done, is I hired a guy to do it for me. I think the 560 was a bit different as it was non cab.
the tractor vet
01-23-2007 06:38:37
I mount my addition on the steering support on the left side where the top and bottom come together i drill and tap the support and use a small pice of aluim. and mount everything on it and keep it up so the sheet metal will help keep the rain off . If Snata Caluse would have been good to me and just bought me that camra i wanted i could have showen ya.
