change over from a mag to disturibtor
Baxter-13
01-23-2007 15:04:23
How much do you have to change to take a mag off and put a distubtor on a M
magman
01-23-2007 16:46:24
 Re: change over from a mag to disturibtor in reply to Baxter-13, 01-23-2007 15:04:23
I just sent you an email I can not say I remember you but maybe you can refresh my memory. MagMan
Yugrotcart
01-23-2007 16:10:28
Ryan,
Here is a useful link also. The mag you have is an H4, this manual will help.
Paul
Yugrotcart
01-23-2007 16:21:16
 Re: change over from a mag to disturibtor in reply to Yugrotcart, 01-23-2007 16:10:28
third party image
Try that again..... .....
Baxter-13
01-23-2007 15:53:54
Ok ...i guess im sticking with th amg..i just sent magman an emil about the high out put coil..thanks
-Ryan
Baxter-13
01-23-2007 15:43:37
ook..but where do you get the high output coil..and does it work good??
Yugrotcart
01-23-2007 15:48:16
 Re: change over from a mag to disturibtor in reply to Baxter-13, 01-23-2007 15:43:37
Baxter,
"Magman will have the H/O coil. It is very easy to change, a 10 min job.
Paul
NDS
01-23-2007 15:43:19
They will interchange easily make sure rotor is pointing to same place on both of them before removing and don t let anything move while they are off and they should both be in time. It has been a long time since I changed one out and my memory may be off on the timing part but I think they will only go back in 2 positions in time or 180 degrees off if nothing has moved.
Baxter-13
01-23-2007 15:23:34
because i have a M and a H and the H has a distubutor and the M has a mag..the mag is a rebuilt one..i want to do this because i am goin to use the M for pulling and i am goin to put a bigger coil and elcetorinc igention in it.
Yugrotcart
01-23-2007 15:46:15
 Re: change over from a mag to disturibtor in reply to Baxter-13, 01-23-2007 15:23:34
Baxter,
Speek with Jon the "Magman", he may be able to clarify things for you.
Paul
old
01-23-2007 15:42:26
Stick with the mag, you can tweek it a little and it will do as good or better then a distubutor any day
Yugrotcart
01-23-2007 15:38:49
Baxter,
Put a high output coil in yur mag and away you go. Few will argue that a mag has a better spark.
Paul
Yugrotcart
01-23-2007 15:14:08
Baxter,
Why change it? For $150 you can get a rebuilt mag.
Paul
