what do these markings on the block mean
Baxtr-13
01-23-2007 15:08:56
I have an M as many as you all ready know..but i was looking at the top of the block today (with the head off) and if your standing on the right side of the tractor and looking down it says D on #1-2 cylenders and C on # 3-4..i was just wondering what does this mean..or does it mean nothing at all?? the markings are between the sleeves and where your standing
Janicholson
01-24-2007 06:34:16
 Re: what do these markings on the block mean in reply to Baxtr-13, 01-23-2007 15:08:56
D Slater is correct. I will add that the effect of this lettering and sizing is to cause a bit of hassle in fitting sleeves. Sleeves fit into that bore with a interference fit. The sleve is frozen so that it shrinks and the block is heated so it expands. The sleve is then inserted in the bore rather rapidly to the seating of the top flange in its groove. A bore with an "A" or "B" stamp will usually be fine for sleeves commonly found aftermarket. C may be OK as well. "D" bores will be loose, and may need to be select fit from the sleeves to find a tight one, or be purchased seperately to fit correctly. A loose sleeve will fail in two ways. Either because it stress cracks at the top where it flanges (resulting in the body of the sleeve traveling downward into the crank and rods, which is very not good) or through poor heat condiction and cooling resulting in overheated pistons. I hope this explanation helps, JimN
D Slater
01-23-2007 18:52:26
When the factory finished the bore in blocks they did'nt turn out exactly the same size. Finish bore was measured and marked with code letters A through D with A smallest and D largest.
I'm not refering to a size change you can see with your eyes.
