SUPER C GRILLE
Ken K
01-23-2007 17:31:38
Does any body have a link or a scan of a parts page to see what the proper hardware and brackets are needed to hold grill in place properly? Thanks, Ken
Keith-OR
01-23-2007 19:47:27
 Re: SUPER C GRILLE in reply to Ken K, 01-23-2007 17:31:38
Here is the IH on line parts catalog with the grill, radiator and backets needed. HTH
Keith & Shawn
Patrick in Illinois
01-23-2007 19:41:13
NDS, It is in the online parts catalog. At the search, put in Super C, then go to chassis and click on the plus. It will come up with the list in that category and click on "Radiator and connection" That is the exploded view of the grille and radiator etc... hope that helps. Patrick P.S. Tell us a little about your super C. I have a 1951.
gene bender
01-23-2007 19:19:04
All you need is the bar that bolts to the water outlet on the top bottom bolts to the crank bracket on the steering sector. three capscrews hol it to the tractor. Do you need both?
NDS
01-23-2007 17:45:49
The Case IH parts catalogs are now online. The easiest way (at least for me) to get there is to do a Google serach for "Case IH parts catalog" and choose Case IH--Parts and service--Search for Parts. When you get to site just type in Farmall in Search Slot and choose Super C from list.
NDS
01-23-2007 18:01:34
 Re: SUPER C GRILLE in reply to NDS, 01-23-2007 17:45:49
For lack of something better to do I went to Super C parts catalog and was not able to find radiator or Grille.;
Ken K
01-24-2007 16:39:50
 Re: SUPER C GRILLE in reply to NDS, 01-23-2007 18:01:34
Thanks for the info that online parts book is going to come in handy. Just got the tractor at christmas(present for myself) Nice tractor runs great just trying to fix up a few little things like the grille it was just kind of wrapped around the radaitor and held on with wire and it had carrige bolts with nuts for spacers holding the radaitor on the frame with no cushion so I'd like to fix it before I need to get a radaitor. Looks like I'm going to have to find the upper support bracket for it and the cushions. Does the top bolts on the grille screw into the bracket? hard to tell in the pic. Thanks again
gene bender
01-25-2007 05:56:42
 Re: SUPER C GRILLE in reply to Ken K, 01-24-2007 16:39:50
yes there would be two cap-screws on the top side of the grille going into the radiator support which also serves as a holder for the j-hooks to fasten the hood at the front so this brace holds the radiator,grille and a place for the hoods j-hooks to fasten. This brace is not the same as one for the A and B Looks the same but there is a difference
