priority flow valve
Hydro
01-25-2007 10:17:08
I'm working on a stage II super H. It has Charlyn power steering with the Charlyn hyd. pump that is driven by the fan pulley. I'm going to run the steering motor off of the live hyd. This tractor will not have a loader on it but may be used with a single cylinder implement. Is a priority valve necessary, could I run a line from the pressure side of the hyd. system to the "in" side of the steering motor and another line from the "out" to return oil to the reservoir and not use a priority valve.
Allan In NE
01-26-2007 01:04:30
 Re: priority flow valve in reply to Hydro, 01-25-2007 10:17:08
Doesn't work that way.
Too much oil stalls that steering motor out. It needs right at 3 1/2 gallons and it needs it ahead of the rest of the system.
Put a priority valve right behind the pump. Exhaust port on the priority valve then runs the rest of the hydraulics.
Allan
Keith-OR
01-25-2007 20:55:48
Here is a picture of Allan in Neb's H with flow control valve..
Keith & Shawn
third party image
Steven@AZ
01-26-2007 05:57:18
 Re: priority flow valve in reply to Keith-OR, 01-25-2007 20:55:48
third party image
You can just barely see mine, sitting on the frame rail, behind the mower mounting plate... Mine is the one from Northern Tool that is still adjustable like Allan's, but you need a wrench to adjust mine.
Nat 2
01-25-2007 11:38:00
A priority valve is DEFINITELY necessary. It needs to be installed between the hydraulic reservoir and the two-way valve. Otherwise, you will have no power steering.
Your two-way is "open center" which means that hydraulic fluid flows straight through it and back to the reservoir if it's not operating a cylinder. If you try to run two parallel circuits, one to the two-way, and one to the steering, the hydraulic fluid will take the path of least resistance. In other words, every time the steering motor asks for pressure, the fluid will flow through the two-way valve.
Just FYI, but connect the priority flow to the steering. In a fit of absolute brilliance several years back, I told Dad he should hook the priority flow to the two-way valve... BONEHEAD! Didn't notice it until I was trying to steer the two-rake hitch on a very hilly field. It's no fun when you need to turn the tractor and the rake at the same time going down a hill, and the steering locks up!
Bob M
01-25-2007 11:37:20
I doubt the Charlynn steering motor can safely handle the full flow a Super H live pump. (I'm unsure of the actual numbers but recall the steering motor can flow 2 gpm. The pump I think delivers 8 gpm...)
So depending on how you pipe it up, unless you use a flow divider you'll either overpressurize the steering motor (= blown seals), or else bypass constantly thru the hyd relief valve (= overheated hydraulics and unnecessary load on the engine).
Also as Steve mentions below, without the priority valve your power steering will stop working whenever the external hydraulic cylinder is being stroked.
I'd install a priority valve and do the job right!
Steven@AZ
01-25-2007 10:31:12
You might not get full hydraulic pressure to your cylinder - also you won't be able to turn when running the hydraulic.
I got my priority valve from Northern Tool for about $75, they've gone up in the last few years, I see.
