behlen power steering?
1950mfd
01-25-2007 17:21:30
Im looking at a 450 farmall with behlen power steering. is this a good setup or not?
1950mfd
01-26-2007 10:21:37
 Re: behlen power steering? in reply to 1950mfd, 01-25-2007 17:21:30
Thank you for the answers. I think i am going to buy the tractor.
Harlen Larson
01-25-2007 20:34:33
It isn't too bad if it isn't sloppy. Usually the steering box is worn out. The only thing with these though is that its common not to have much for power steering when your not moving which is when you actually need it the most.
RustyFarmall
01-26-2007 04:44:06
 Re: behlen power steering? in reply to Harlen Larson, 01-25-2007 20:34:33
My 1950 H has the Behlen power steering, and it is my loader tractor. I was never real happy with the power steering, although it was better than not having it. Eventually one of the hoses started leaking, so in the process of replacing both hoses, I also completely flushed the system and refilled with ATF. I don't know what oil was in it before, but it was thick and heavy. The power steering works like a champ now, even while standing still.
