Kirk in kansas,
01-25-2007 18:45:39
where do I find hyd part,s for a 51 W-6 standard? I need the little box, and lever that go on the inside of left fender, and the 2 nipple,s that join it all together, to the hoses that go in that cover on lower left side of seat, I have a metal stancion on the back for hose,s , But it not for a W-6 I dont think? Need steering gear,drag link,radius rod,& tie rod, they have tab,s welded to them so i cant use them, somebody tried power steering on this thing, and they had to weld all this suff together to make it work and a dumb steering damper on right side welded to radius rod, and weld,s all over spindle,s too with the drag link, on one side, & steering cylinder on other, arghhhh where,s a hood too, hole cut in end for 12 volt gen, H & M wheel,s on front end with 7-50-16 mud truck tire,s on front,s,(one side turned backward,s), dont know if it supposed to have light,s on front or not/ No hole,s under light stem hole,s on side of hood this thing need,s help BAD! all botched up
