FARMALL H 1951 REAR RIMS
city farmer
01-26-2007 11:22:34
CAN YOU PUT TUBES IN THE REAR WHEELS DO NOT NEED WATER IN THEM FOR WHAT I DO BUT THE RIMS NEED SOME WORK AND RE PAINT THEY HAVE SOME BAD RUST SPOTS ON ONE RIM BUT WOULD LIKE TO MAKE DO INSTEAD OF BUYING NEW ONES IF I HAVE TO BUY NEW ONES WHERE SHOULD I LOOK THANKS MARK FL.
Janicholson
01-26-2007 16:24:09
 Re: FARMALL H 1951 REAR RIMS in reply to city farmer, 01-26-2007 11:22:34
They have tubes in them now. Clean the rust, chemical derust paste, wire brush, and effort. If they are thinned to the point of small pin holes, or thin sections, they are better off recycled for scrap. When clean, I would use a two part epoxy paint and apply it several inches beyond the rust. They look ok painted hammer tone silver, or galvanized "color" paint. If there are rough spots, sand them befor painting. Thin rims will (have) blown the sidewall out making a terrible noise, possible bodily injury, and property damage. Been there seen the results. Rims are available rather frequently. Check Salvage yards, farm tire stores, and put a add on this site. 38" Rims from early John Deere are identical (color may vary from the IH silver) JimN
Dave_Id
01-26-2007 16:21:25
I have repaired rims that have rusted thru by grinding out a hole until I hit solid metal, then making a patch and welding it in. Grinding off the weld and you can't tell it's been repaired.
MIKE FRENCH
01-26-2007 11:43:41
If the rim is rusty on the inside, clean it up the best you can and rap the insid of the rim with duct tape, this keeps the rust from cutting the tube.
