farmall performance parts
Craig Michigan
01-26-2007 22:35:16
Hello,can anyone tell me who I can order performance parts for a M from,I will not buy anything from DENNY'S CARB SHOP anymore!!!!! !!! THANKS
Craig Michigan
01-27-2007 15:42:18
 Re: farmall performance parts in reply to Craig Michigan, 01-26-2007 22:35:16
Thanks for info,I"ve pulled my stock M for about 2 years,now I want to make some power,looking for 306 cube pistons sleeves,custom header/intake,lighter front bolster,governor work,and carb work I"ve got all the ignition work done.I think anyway..... how much can a stock m head be shaved with high dome 4 1/8 inch pistons?Is this a smart moove for more compression and power?what about top end,valvesand the rack?
Andy Motteberg
01-27-2007 15:46:16
 Re: farmall performance parts in reply to Craig Michigan, 01-27-2007 15:42:18
Sounds like a lot of work to be done. You should post in the Tractor Pulling discussion board, Chad S seems to know a lot about pulling tractors and he is in the Tractor Pulling board. Good luck.
Andy Motteberg
01-27-2007 15:12:22
What kind of performance parts are you looking for? I might be able to help you. Andy.
big red fred
01-27-2007 08:27:38
You sure are right dingy`s carb shop ,I can`t belive he is still in business .
champspa
01-27-2007 05:18:49
Murphys Motor Service
RustyFarmall
01-26-2007 22:47:36
Another unhappy customer. I've never bought anything from them, but I've seen his work. 'Nuff said.
Go over to the tractor pullin' forum and post a message for Chads.
SMP
01-27-2007 10:51:16
 Re: farmall performance parts in reply to RustyFarmall, 01-26-2007 22:47:36
Paul Marlatt or Lemmons in Rushville In.
metalhead
05-30-2007 11:28:14
 Re: farmall performance parts in reply to SMP, 01-27-2007 10:51:16
I would highly suggest skipping Paul Marlatt. He has messed up a thing or two...royally and not stood behind it. Lemmons, however, is great. I've always been super pleased with them.
