m carb
stevezim
01-27-2007 09:12:29
i have 2 m's from my dad which wer purchased in 1949 and 1950.Both tractors start and run fine except sometimes the carb will overflow when cranking.seems to happen more in the winter and i know they did it occasionally for my dad but now have gotten worse.any suggestions please
Tom43
01-27-2007 12:37:11
 Re: m carb in reply to stevezim, 01-27-2007 09:12:29
Dear Steve,
Usually the problem you are experiencing can be fixed with a new needle and seat. While you have the carburetor apart be sure the float doesn't have fuel in it. Sometimes the float rubs the float bowl causing the float to stick in the down position. I have had the best luck with the viton tip needle and seat.
City-Boy McCoy
01-27-2007 12:29:11
Rebuild your carburetors. While you are at it, make sure your sediment bowls and fuel lines are clear of trash. mike
