Help!! 674 wont move after out of frame engine o/
big red 1
01-27-2007 17:40:43
Recently helped a friend get his new motor running in his 674 Gas
After starting it,we went to back it out and it wouldnt move-nor would the engine pull down when put in gear-its not a HYRDO.
ANY IDEAS AS TO WHAT TO LOOK FOR.
THANKS IN ADVANCE
Randy
MN Scott
01-27-2007 19:16:59
 Re: Help!! 674 wont move after out of frame engin in reply to big red 1, 01-27-2007 17:40:43
About the only things I can think of is did you remember to bolt the clutch cover to the flywheel after the tractor was rejoined? Did you adjust/assemble the clutch properlly? Remove blocks/shipping bolts from the clutch fingers?
