Update On Frozen 806 Hydraulics
Harlen Larson
01-27-2007 18:15:24
Not much to say, Still frozen. Yesterday temps hit 30 in the afternoon for a short time and I plugged the tank heater in for about 3 hours and it started just like it was warm out but still no hydraulics. The pto does not run either. I haven't tried any other kind of warming yet or checked anything else.
Harlen Larson
01-28-2007 07:48:43
 Re: Update On Frozen 806 Hydraulics in reply to Harlen Larson, 01-27-2007 18:15:24
I don't get the difference with the pto. That runs off hyd pressure to right? Going down a steep hill the pto will quit because it loses fliud pressure so wouldn't this be the same thing?
Allan In NE
01-28-2007 08:22:51
 Re: Update On Frozen 806 Hydraulics in reply to Harlen Larson, 01-28-2007 07:48:43
Harlen,
On large frame tractors, the front pump runs steering, brakes, T/A and tranny lube. Rear pump runs remotes and hitch. Finally, the PTO pump runs just the PTO.
If you have no hydraulics whatsoever, you look for a common denominator, which is either NO HYDRAULIC OIL or the mechanical drive to those three pumps is defective.
If the tractor is full of hydraulic oil, it has got to be split and repaired because you've lost your "live power".
Allan
third party image
the tractor vet
01-27-2007 20:52:38
YEp , it's going to have to be split and a new PTO input installed and a new pressure plate and ya just might as well have the flywheel ground and a new clutch disk new throw out bearing pto input bearing and seals and be done with it . This is going to get into the cookie jar . And she ain't going to heal herself.
JayWalt
01-27-2007 22:14:52
 Re: Update On Frozen 806 Hydraulics in reply to the tractor vet, 01-27-2007 20:52:38
Hopefully I have put the cover back on my cookie jar, but I better shutup before my clutch starts slipping!!
It sucks when something like this happens. I know if my engine croaked or something major went that would cost more then a couple hundred, I'd problem just sell mine, unfortunately you either sell it, take a lose, or fix it and spend more money and never see a return once its in there. Hopefully its not something too major and can be readily had for a little money. If you lived around here, I'd help ya out even tho I dont know what its all about down there, but I am good with a wrench...
MN Scott
01-27-2007 19:08:12
Since your PTO does not run you have a mechanical problem not an ice one. Most likelly your pto drive gear has snapped or the drive splines in the clutch cover have stripped. Your going to have to split the tractor at the clutch housing to find what part or parts let go and replace them.
IH2444
01-28-2007 10:27:21
 Re: Update On Frozen 806 Hydraulics in reply to MN Scott, 01-27-2007 19:08:12
also figure out why it snapped. Could have been ice in the pump ?
MN Scott
01-28-2007 11:29:11
 Re: Update On Frozen 806 Hydraulics in reply to IH2444, 01-28-2007 10:27:21
Most likelly not ice. The PTO drive gear is a weak spot in IH tractors. Could have been failing and the cold oil was just the last straw.
