1086 troubles
Erik in WI
01-28-2007 07:54:27
My neighbors 1086 has a bit of an interesting thing happen to it when he is using the PTO on his baler and pushes in the clutch to stop. Right after the tractor stops, It "jumps forward like something hit you from behind." I can think of only two things that would cause this, either the TA in the 10, or something in that John Deere square baler. I don't know if it does it on any thing else he runs with the PTO, or if the tractor is in TA or DD.
Next time I see him I will ask a few more questions, but does anyone have any other ideas?
Thanks
Erik
the Unforgiven
01-28-2007 09:04:43
 Re: 1086 troubles in reply to Erik in WI, 01-28-2007 07:54:27
Hi Eric, my 10 was doing the exact same thing regardless of the pto. At first it would make a deep heavy thump like a steel bowling ball being dropped on a steel deck, then a softer thump about a second later. Would make this sound just a soon as it stopped rolling. If it was good and hot you could be sitting still, push in the clutch and you could hear the thump after a couple seconds. After a couple more years of punishment the thump became the "jump forward" that you describe, feels like you just got rear-ended by a moped doing about sixty mph. I think it was a clutch in the TA that would grab at the last minute. There were loose pieces falling out of my TA unit like rain when it came out! Anyway, I am confident it is the TA causing your trouble. While it's open you just as well do a clutch and input shaft, the splines were almost gone on mine, and my trans brake was so far gone that I forgot it had one! I don't do any haying or overloading so I went with the TA eliminator
