444 remotes
kinbo#3
01-28-2007 08:25:24
How do I go about adding rear remotes to a 444 with none? I found the lever and valve that go under the seat at a junk yard off of a similar tractor (dont remember model).I didnt buy it yet.
Do I need a line to the pump? Or can I do this a
different way?
IH2444
01-28-2007 10:24:16
 Re: 444 remotes in reply to kinbo#3, 01-28-2007 08:25:24
The pressure feed line will tap onto the body that attaches to the front of the liftbox under the seat.
It will feed both the valves (located seperately on the left front of the rear end) and the 3 point lift.
