Order Farmall Cub Parts Online
differential oil for Cub
Farmall Ed
01-29-2007 08:05:54
I have a 48 Cub and have had to do some work on the power take off. The pin on the lever that moves the clutch was worn off smooth. Just picked up the new part at the IH dealer (not cheap). The parts man says use Hyd oil in there. It looked like regular gear oil when I took it apart. Any of you Cub fellows know what I should use? Thanks ED
Nat 2
01-29-2007 11:10:28
 Re: differential oil for Cub in reply to Farmall Ed, 01-29-2007 08:05:54
Gear oil is just fine, either 80W90 or 85W140.
chadd
01-29-2007 09:03:54
You can use either one. 80-90 Gear Oil has been around longer than hydraulic fluid, so that was what the manual recommended. Hydraulic fluid will work, but be aware that it will leak out a lot easier too.
old
01-29-2007 08:33:11
When we redid all the seals etc in my friends cub we used 80W-140 in his and it has worked just fine for 2 or 3 years now. Tranny etc. works good with that stuff in it
