smoky AI
nspec
01-29-2007 10:59:03
I"ve got a 47 AI that smokes a bit. Blue smoke, obviously oil. I"ve got it isolated to the rearmost cylinder (only one with wet fouled plug.) Only clears up a little when warmed up and made to work hard.
The thing is, it runs very strong. You"d never know anything was wrong. When I bought it, she had new rings put in and the head was machined. I"m thinking I"ve got a leaky valve guide. Any thoughts from anyone on where to start?
Thanks in advance for the help.
Farmall Freak
01-29-2007 14:38:41
 Re: smoky AI in reply to nspec, 01-29-2007 10:59:03
I agre 100% with with Andrew Z.
Andrew Z
01-29-2007 13:47:35
It sounds like a valve guide is gone to me espically if the others clear up after its warm. that sounds like how my A is it smokes for a couple of sec's then it clears up. Does it consume alot of oil? if it does not and holds oil pressure then I would not worrie about it to much.
Andrew
