No Brakes !!!!! 674 International
Scotty1
01-30-2007 19:04:19
Hi, Got no brakes at all. Got no resistance at all when I press on the pedal. Where do I start ?
Thanks for your time and any help!
Scotty
Scotty1
02-01-2007 04:35:34
 Re: No Brakes !!!!! 674 International in reply to Scotty1, 01-30-2007 19:04:19
Thanks everybody. I have a starting point now and I'll start bleeding the air out and see if that brings the pedal up. Thanks again !
Scotty
Fromjb2
01-31-2007 14:52:21
Hi Scotty, best to bleed the brakes when the Hytran fluid is at operating temperature.
JimB
Ted in NE
01-31-2007 05:42:22
Leave the engine running when bleeding the brakes. Oil is supplied to the master cyl. through an orfice in the oil cooler return. Will bleed faster if you locate the small hose under the hood with the orfice in it. Temporally replace the hose with one without the orfice while bleeding, make sure the orfice is clean while it is off. Have to have the orfice back in place for normal use, to much oil will cause brake drag without it.
JRD(VA)
01-30-2007 19:32:17
Make sure the hytran is up to full mark in rear, either take cover between floor boards or small side shield off, pinch off the return hose from the brake master cylinders, now you need to bleed the brakes. Do it like you would on a car, the bleeders are just above the rear axle housing, one on each side.
