Farmall H Flywheel
Joshua Lawton
01-31-2007 10:14:17
I need to replace the ring gear on my flywheel as the teeth are ground off. Can this be done without splitting the tractor? Can I get the flywheel out through the clutch housing and liftall cavity? Thanks for any help or tips!
Theman
01-31-2007 10:49:05
 Re: Farmall H Flywheel in reply to Joshua Lawton, 01-31-2007 10:14:17
The clutch housing narrows down too much at the starter to get the flywheel out that way. It will have to be split. When you get the flywheel out, check the back side of the ring ger teeth. They can be turned around and re-used if care was taken when they are removed - provided no teeth are completely broken off.
Joshua Lawton
01-31-2007 11:49:36
 Re: Farmall H Flywheel in reply to Theman, 01-31-2007 10:49:05
I was afraid of that, but was hoping to be pleasantly surprised. Thanks for the information. I"ll be tearing her apart this weekend. I really appreciate the information!
Josh
RustyFarmall
01-31-2007 12:06:24
 Re: Farmall H Flywheel in reply to Joshua Lawton, 01-31-2007 11:49:36
Even if it would fit down through the opening, which it won't, that flywheel is much heavier than what you would want to try and hold onto while lying on the ground underneath it.
