706-806
mCMP
01-31-2007 14:25:43
Building a pulling tractor, would a 706 rearend & trans be lighter than a 806 ?
ejr-IA.
02-01-2007 10:39:57
 Re: 706-806 in reply to mCMP, 01-31-2007 14:25:43
Their can be a difference in the ring gear carriers on the 706 and theirs a different part No. on the bull gears also may be a tad narrower.Around here the guys want the 706 rear ends with the lighter 38'' rear cast centers and the lighter 3pt for stock pulling and useing the 66 center section and 66 engine.
the tractor vet
01-31-2007 17:04:37
NOPE !!!!! SAME SAME.
wolfman
01-31-2007 19:37:21
 Re: 706-806 in reply to the tractor vet, 01-31-2007 17:04:37
That's why they always use a 460 rear casting with an 806 or combine engine. 5000 lb and less is very doable.
wolfman
01-31-2007 19:39:00
 Re: 706-806 in reply to wolfman, 01-31-2007 19:37:21
Those 706 thru 1486 rear end housings are massive. Did I say heavy?
