timing an H
Baxter-13
01-31-2007 17:17:06
I went to retime my H with a mag(if u read my post eariler, im just putting it on to get it started then im putting it back on the M after i get to that point) ok i could not find any timing mark on the flywheel, i know what it looks lke and where they are at, but could not find it. I saw the point that is supposted to line up with the notch, but could not find the notch. Is tere any thing diffrent on an H that would make me not find it. Also what way does the dis. drive gear trun when its runnig?
Thanks
-Ryan
Baxter-13
02-01-2007 13:32:15
 Re: timing an H in reply to Baxter-13, 01-31-2007 17:17:06
yea i meant the crank shaft pully...ook i will try to get it
Thanks
-Ryan
GAUU6
02-01-2007 09:57:28
After you find the timing mark,or however you get #1 at TDC,be sure to turn the magneto coupling opposite its nomal rotation direction till the arm points to the #1 terminal in the dist.cap
Hydro
01-31-2007 18:45:53
I'm not sure if you misspoke or not but you said you were looking for a notch on the flywheel. The notch you are looking for will be on the front crankshaft pulley.
Janicholson
01-31-2007 18:13:59
FInding TDC on #1 is pretty easy (especially if you have a hand crank) Pull #1 plug (close to radiator) and place your thumb, or a round end stick big enough to not go through the sparkplug hole) crank it till air blows out somewhat. That is the compression stroke. Look in the spark plug hole, You can see it, or feel it with a piece of solder, to get the piston precisely at TDC.
At that point, finding the mark is a matter of cleaning. Put whiteout, or chalk on the mark and clean around it. JimN
