1982 Model 784 Diff. lock Issue
Mich John
02-01-2007 12:26:17
I managed to free up a stuck diff. lock system by spraying penetrating oil between the lever and the diff case and tapping the pedal. Now I have the reverse issue - it will not dis-engage. I took the rod loose from the pedal and tapped on the lever but it would NOT release the diff lock. I don"t have a good schematic showing what the diff. lock fork engages to lock the diff. How much force (torque) could I apply to the lever without causing an issue. I will try to apply a vibratory load to the lever next to see if it breaks anything loose. Anyone else faced with the same concern and fixed or have any suggestions?
Mich John
02-02-2007 14:18:00
 Re: 1982 Model 784 Diff. lock Issue in reply to Mich John, 02-01-2007 12:26:17
The issue is resolved - the rod was bent (about 80 degrees; parts book does show a slight bend). I took the rod loose at the pedal and hammered the lever back into the dis-engaged position (also verified by a drive). I will now straighten and strengthen the rod, reinstall and continue to operate the diff lock to reduce some of the friction.
Mich John
02-02-2007 12:15:37
On further inspection, part of my issue is also due to the actuating rod clearance to the auxil- iary valve housing; it is against it. I will take off the rod and bend it to get more clear-
ance, adjust the rod to the full length, stretch the pedal return spring to the max. and see if I can then lift the pedal (while turning left to right). Otherwise, I"ll still keep trying to break it loose to the dis-engaged position by hitting the shaft lever. Stay tuned.
Bernard le mécano
02-01-2007 13:48:37
Hi, Mich, may be the shaft is stuck, by rust, in the housing. It have a O ring each side of the housing but externaly. You can't, spray any loose nut on the shaft, because the O rings. You may have to lift the hydrolic cover for access the shaft. Bernard le mécano Québec Canada
TWL
02-01-2007 13:13:24
My 684 was the same way.Sometimes it will stick.While moving,I lift up on the pedal and turn the steering wheel both directions.It has never failed to come up this way.
