IH 1066 wheel spacing
JimmyD2
02-01-2007 13:02:47
Hi,
Does anyone know if an 1066 with 18.4 x 38 rears and an red IH cab will narrow down to 60 inch wheel spacing. I know one without a cab will but I am not sure about the cab and we would like to use in for cultivating.
Thanks in Advance
Hugh MacKay
02-01-2007 13:39:06
 Re: IH 1066 wheel spacing in reply to JimmyD2, 02-01-2007 13:02:47
Jimmy: I know I had my 20.8 at 66 with ROPS cab. If I remember correctly there was about 3" between tire and cab. You should be able to make it with 18.4.
I'm glad your the one running it, even at 66" I was afraid to take my duals off. Like Allan said last week,"I think it blow over in the wind."
Allan In NE
02-01-2007 14:35:18
 Re: IH 1066 wheel spacing in reply to Hugh MacKay, 02-01-2007 13:39:06
It's funny how a guy gets used to that.
I had three of the jokers sucked in on 60" centers and after the first initial "jolt", really didn't think any more about it.
'Course, land in this country is flat as a tabletop too. :>(
Allan
third party image
Hugh MacKay
02-01-2007 15:19:11
 Re: IH 1066 wheel spacing in reply to Allan In NE, 02-01-2007 14:35:18
Allan: After I set my tractor in from 84" for duals, I only ever had the duals off twice. First and last all in one operation. Why a even dropping in a plow furrow made you feel like you were going over.
Seriously I found tread wear to be far less with duals on. My 1066 went through it's first set of tires in 1,000 hours running single, bias ply. I dualed it with same tire and got between 8,000 and 9,000 hours. My duals were the close space type, had them on both 560 and 1066. Any cultivating I did, I had a 4 row set up for my 130. My larger tractors were always busy with haylage at cultivating time. 130 was quite comfortable on 60" centers, and I could cultivate corn between milkings, and the boys just kept filling silos.
Allan In NE
02-01-2007 13:14:36
Sure will,
This one was set up to cultivate 30" rows.
Allan
third party image
IaGary
02-01-2007 16:54:57
 Re: IH 1066 wheel spacing in reply to Allan In NE, 02-01-2007 13:14:36
I got one just like that without the cab and dauls.
Same spacing also.
Allan In NE
02-01-2007 17:03:59
 Re: IH 1066 wheel spacing in reply to IaGary, 02-01-2007 16:54:57
Thought you'd get a kick out of that picture. :>)
Be sure and post up your progress as ya go, okay?
Allan
IaGary
02-02-2007 04:54:51
 Re: IH 1066 wheel spacing in reply to Allan In NE, 02-01-2007 17:03:59
Will do.
