2350 loader decal location help please
pt756
02-02-2007 07:54:43
got the 2350 sandblasted and repainted, was putting cylinders back on and would like to know the correct location pf decals, dealer sent a 35 inch international decal that doesnt look right on there, have 4 inch numbers i think that ic correct, also have a 5 by 7 ih emblem, plus all the warning decals, sure would appreiate any help or pictures, not many around here to look at or to see a manaul or a product guide thank you it loks like everything might go on the frame where the 2 arns are welded together?
K.B.-826
02-02-2007 16:58:16
 Re: 2350 loader decal location help please in reply to pt756, 02-02-2007 07:54:43
I beleive the the warning decals go toward the top on the rear of the left side of the frame, so you can see them from the seat. I'm sure the correct police won't get worked up if you don't have those exactly right.
Nat 2
02-02-2007 11:09:12
Best I can recall from memory:
INTERNATIONAL: goes down the horizontal of the loader arms.
2350: goes below the INTERNATIONAL, roughly centered.
IH logos: Go on the gusset plates where the loader arms bend down. I believe the logo should be vertical when the bucket is on the ground.
MOUNT-O-MATIC: Goes on the cross piece that connect the two loader arms in front of the tractor, centered.
