Super H brakes AGAINNNNN!!!
Andrew Z
02-02-2007 13:02:34
OK, I thought I had solved the problem, but was running her today and she stated the ol' lock up deal!!! :( I know the brakes are clean, I was thinking what is next do I replace the balls, the springs, or the whole thing? I dont realy know what the heck to do now!
Thanks for the help
Andrew
Janicholson
02-03-2007 08:00:46
 Re: Super H brakes AGAINNNNN!!! in reply to Andrew Z , 02-02-2007 13:02:34
When they are apart, I have found, looking particularly carefully at the grooves in the ramps will tell much of the story. As aluded to By T Vet, the ramps get wear spots at he point they were operating for years. These wear spots are very slight depressions that will allow the balls to "fall" into them when applied. The result is instantaneous locking of the brake, and even more wear in the dent I am refering to. Very careful removal of that depression using a stone of exactly the correct size (in all 12 grooves) willwork. Getting different disks will cause them to be running in a new location, Machining the housing will also change the dynamics. The best is new/replacement expander setups. The disks wear so slowly that the wear on the ramps is focused on one spot on each ramp. Ball roundness is important, but only found in a few instances. JimN
Roger Mills
02-03-2007 06:09:51
You can get small squirt tubes of graphite for lubricating locks at Walmart etc. It comes either dry or with a liquid baxe. I have found it stays where you put it very well and does not attract dirt. Very fine texture and very slippery.
Dennis Minn
02-02-2007 19:56:57
Just a bit of thought.....had you paid attention about the disk brake orientation? I know that if the disk brakes are installed "upside down" that you may find yourself with a locking brake. Let me explain, remove the brake outer shell, and then you get to the balls/guides/disk area. Keep in mind, you can easily flip the ball and expanding plates assembly in the wrong way, kind of like a 6 oclock to noon orientation. I know, I did this and the locking brake syndrome occurred. If need be, I describe in more detail, keep in mind that the disk expanding section can be flipped. Hope this helps,
Dennis.
RR Mech
02-02-2007 20:50:55
 Re: Super H brakes AGAINNNNN!!! in reply to Dennis Minn, 02-02-2007 19:56:57
I have did many disc brake jobs from the letter series up through the 656 series and they are all the same and there is no wrong way to put them together. both plates are identical. The main thing to do is to clean any contact points where the actuators touch the drums.
Andrew Z
02-02-2007 20:03:08
I never thought about that. I thought they could go on either way no direction. I looked in the manual when repaing them and nothing was said about that. However it makes sence, soo what is the correct side up? cause Im not really sure?
thank you
Andrew
JayWalt
02-02-2007 15:37:49
You can most likely use speedometer cable lube. It does have a fluid carrier that evaporates in short order. It is gaphite based as well
teddy52food
02-02-2007 14:57:22
John Deere used to have powdered graphite. Also check with someone that does shotgun reloading. It is used with reclaimed shot.
the tractor vet
02-02-2007 13:20:28
Clean up the ramps buy some new balls that are cromed or stainless and use graphit(SP) to lube the ramps and amke sure that there is not a bunch of ware in the drums if you are pulling the plates all the way out to the end of the ramps then you will have to have some of the drum milled off so that with new disc and everything stacked in the drum that you do not have more then about and 1/8th of and inch clearance .between the edge of the drum to the top of the disc.
Mich John
02-02-2007 14:23:27
 Re: Super H brakes AGAINNNNN!!! in reply to the tractor vet, 02-02-2007 13:20:28
By enclosing an abbreviation such as the tractor vet did, he means he's not sure of the spelling. (SP) or (sp) means not sure of the spelling - the correct spelling in this case was graphite.
Andrew Z
02-02-2007 14:29:21
 Re: Super H brakes AGAINNNNN!!! in reply to Mich John, 02-02-2007 14:23:27
Gotcha, I thought it was some kind of spray or something. Im not up to date with computer short hand very well!?!?! Where can I buy graphite I assume in the powder form.
Thanks again
Andrew
Andrew Z
02-02-2007 14:15:52
Thanks Tractor Vet. thats what I was thinking, I was suppose I'll replace the springs at the same time. I sorry to be ignorant but what is SP graphit? Thanks for the help
Andrew
