606 clutch adjustment
jhill52
02-03-2007 06:09:03
What is the correct method to adjust the clutch on a 606 with a T/A. I can't get it to go in gear without grinding unless I put the T/A in low. TIA
Jerry
K.B.-826
02-03-2007 08:03:12
 Re: 606 clutch adjustment in reply to jhill52, 02-03-2007 06:09:03
You need to get yourself a I&T manual. It's too complicated to explain, you need to see the diagrams to understand. Sounds like the TA linkage is out of adjustment. Follow the procedure to the letter.
