H hitches-half speed tinkering.
Tom Windsor
02-03-2007 22:13:07
Well, after visiting the local scrap yard and design, cutting and welding, I now have a 3 point hitch system that I can insert a Ball, a pendle hitch and remove that and insert regular draw bar. So, I am saying that I can pretty well hook up anything to tow to my H. However, I learned the weakness...and that is, the cg is shifted so far back that the front wheels come off the ground quickly. So, next weekend, I will cut out and weld up a hanger to bolt onto the front rails to receive the 96# weights. Maybe 4 of them. That might keep the wheels on the ground.
Anyway, tinkering around is fun---but it is hard to tinker seriously with one hand working and the other in my pocket to keep from banging the sore thumb---did you ever try to light a torch with one hand and adjust it?
TW
ChadS
02-04-2007 10:25:29
 Re: H hitches-half speed tinkering. in reply to Tom Windsor, 02-03-2007 22:13:07
Build you a front weight bracket, that can hold 7-10 75# Ih suitcase weights. They would bolt in the frame bolts along the side, make them as long as you need them, I ran mine the full length of the rail on my 40 H, The frame rail is 4 inches wide I belive,, Find a weight bracket of a 460-856 IH tractor, and bolt everything up, and have a nice looking setup. Antique pullers dont want heavy wide fronts,, if a narrow front was available stock. Chad
Tom Windsor
02-04-2007 17:02:20
 Re: Att: Chad in reply to ChadS, 02-04-2007 10:25:29
Chad
I have a whole pile of the suitcase weights. I sure would like to see your engineering. Can you send a photo to twindsor@aol.com
Tom Windsor
farmerjohninpa
02-03-2007 22:54:44
ya tom its too dang cold out there now to turn them controls with your teeth,,might just freeze up to it. please be careful with that nose lite "h", been many an accident with those just being stock !! good luck
kfox
02-04-2007 07:00:37
 Re: H hitches-half speed tinkering. in reply to farmerjohninpa, 02-03-2007 22:54:44
Tom, You might consider a wide front end, if you don't have one. Lots of extra weight there. Then you can add front wheel weights (if you can find them) I've been looking for two years, and only found one (1) weight. I think the pullers must have them all hoarded up. :-) ken
gene bender
02-04-2007 17:11:25
 Re: H hitches-half speed tinkering. in reply to kfox, 02-04-2007 07:00:37
Hey there is almost a pait of front wheel wts on e-bay all the time sometimes price is pretty cheap as they are worth 150 of so a pair.
